The Cooler Master CK530 v2 keyboard for less than 60 euros!
The CK530 v2 from Cooler Master is a reference that we know well at OCC since we had it in test in 2021. Moreover, it is also regularly in promotion. Today, it is still on sale since we find it until tonight at less than 60 euros against 90/95 euros usually.
Cooler Master CK530 V2
With the CK530 v2, we have the right to a compact keyboard (TKL). It measures only 380 (L) x 135 (W) x 40 mm (H) for a weight of 739 g without the cable. Otherwise, it is a mechanical reference with blue, red or brown TTC switches. Moreover, it has ABS keys (PBT for Corsair ‘s solution but for much more expensive too). The latter are double injected, they will allow the letter on the key not to fade over time. Similarly, the CK530 v2 has RGB LEDs. For its characteristics a little more “technical”, the CK530 v2 has a polling rate of 1 GHz and a response rate of 1 ms / 1 GHz. We also have an internal memory of 512 kB to keep the settings of profiles.
Where and at what price?
The CK530 v2 from Cooler Master is currently priced at €59.99 on the CDiscount website. This is an interesting price since it is normally found between 90 and 95 €. It is far from the 119.28 € announced by the store.
To access the CK530 v2 promotion, go here!
