TA120 EX Mini White : a compact tower fan for Thermalright !
More Thermalright as the brand announces the arrival of its TA120 EX Mini White. You will have understood, we are dealing with a compact and white heatsink… With such a name, these clues do not go unnoticed.
TA120 EX Mini White: a 120mm fan with a height of 135mm!
Thermalright TA120 EX Mini WhiteWith this new reference, the brand offers us a completely white heatsink. Moreover, what “shocks” the most are its dimensions considering its format. Let’s specify that it is a single-tower 120mm fan, nevertheless, its height is limited to 135mm without the fan.
For this format, the brand integrates a total of five copper heatpipes of 6 mm each and a total of 42 aluminum fins. Moreover, we can’t help but notice their slim 45 mm deep profile. And as usual, Thermalright uses C1100 copper for the base.
Concerning the ventilation, we have a single fan in 120 mm powered by PWM. This one will be able to go up to 1850 RPM, which proves to be rather fast for aircooling. Moreover, the air flow will reach 82 CFM and the static pressure will climb up to 2.1 mmH2O.
For the moment, even if the data sheet remains incomplete, we suspect that it will be able to mount on AM4 and LGA-1200 and LGA-1700 sockets.
This way to the thermalright datasheet!
