From Thermaltake, we note the arrival of new fans. The company is launching its Swafan GT12 and Swafan GT14, non-RGB mills with interchangeable blades. What’s more, Thermaltake offers a fan without aRGB diodes in every sense of the word. Joking aside, to keep things simple, we’ve got fans inspired by the Toughfan series with three sets of blades, enough to be comfortable in any scenario!
Swafan GT12 and Swafan GT14: non-RGB fans with interchangeable blades!
This new fan is available in 120 mm and 140 mm sizes. As we said, they come with interchangeable blades, which is very practical for cleaning purposes. On the other hand, you can enhance the aesthetics of the assembly by masking the blades. In addition, each fan comes with three sets of blades, enough to be at ease in a case or on a radiator.
Aesthetics are straight out of the Toughfan series, with a black frame, reinforced motor and gray silentblocks.
In terms of specifications, the 120 mm fan will operate from 500 rpm to 2000 rpm. Depending on the blade set, we’ll have :
- Optimized static pressure :
- Air flow: 54.71 CFM
- Static pressure: 3.17 mmH2O
- Optimized air flow :
- Air flow: 62.23 CFM
- Static pressure: 2.7 mmH2O
- Inverted blades :
- Air flow: 58.17 CFM
- Static pressure: 2.23 mmH2O
In 140 mm, the fan will be just as fast, operating from 500 rpm to 2000 rpm. However, both static pressure and airflow increase with :
- Air flow: 100 CFM
- Static pressure: 3.33 mmH2O
- Air flow: 109 CFM
- Static pressure: 2.76 mmH2O
- Inverted blades :
- Air flow: 107 CFM
- Static pressure: 2.48 mmH2O
To answer the question of price, these fans are clearly not cheap. The official price is $34.99 for 140 mm, compared with $29.99 for 120 mm. At present, only the 120 mm version is on sale in France. Expect to pay between €30 and €40 on Alternate or Amazon.
Here are the Thermaltake product sheets!
