Summit M Pro: a CPU water block signed Bitspower!
Bitspower, known for its components for the world of custom watercooling, announces a new waterblock. On the program, we find the Summit M Pro, a model designed for Intel and AMD processors!
Summit M Pro: a new waterblock for Intel and AMD sockets!
Bitspower Summit M ProWith its new waterblock, Bitspower offers a block for Intel and AMD processors. At first, we learn that this model will be available for LGA-1700 and LGA-1000 sockets. AMD compatibility will only come later, when the company has launched its latest CPUs.
Otherwise, as for the dimensions, the block displays 92 mm on the side with a height of 19.65 mm. Regarding the materials, we find a highly conductive copper base while the upper part seems to be made of acetal. Moreover, on the top, we note the presence of two threads in G1/4″ for the inlet and outlet of the coolant.
Otherwise, the brand announces a powerful block and allowing an optimized flow maximizing the flow inside. All this should be felt on the performance: improved by 15% according to the manufacturer.
Finally, we know that this product is already available for purchase. Via the brand’s online store, it will cost you about 75 € after conversion and this is without taking into account shipping costs and other taxes related to the import.
Here is the technical data sheet of Bitspower!
