Squama 3805: a 38 mm-thick fan from Geometric Future
The Geometric Future brand announces a new product, a new fan to be precise. With its Squama 3805, the brand is launching the thickest 120 mm fan on the consumer market. The objective is clear: maximum performance!
Squama 3805: the thickest consumer fan on the market!
Geometric Future Squama 3805With this fan, the Squama brand offers us a unique reference. While it has a 120 mm frame, its thickness is much greater than that of other fans on the market, reaching 38 mm here! The aim is to maximize performance!
With a maximum speed of 2,500 rpm, this mill will be rather fast, which allows it to boast an airflow of 115 CFM. Alongside this, we find a static pressure that soars, literally, with 6.82 mmH2O! Such pressure is clearly useful for use on watercooling radiators. However, beware of the thickness, as this factor is likely to cause problems during installation.
Otherwise, the fan features aRGB lighting on the blades, which are translucent. The blades also feature asperities, as does the inside of the frame. The aim is to limit disturbance and noise. Finally, rubberized silentblocks are used to reduce parasitic vibrations.
In terms of price, these fans aren’t even that expensive. On Amazon.com, you’ll find the three-pack in black for $59.90. All we have to do now is wait for them to arrive on Amazon.fr.
Click here for the Geometric Future product sheet!
