At be quiet! we’re announcing new fans with the Silent Wings Pro 4 White. These high-performance fans are capable of speeds of up to 3000 rpm!
Silent Wings Pro 4 White: 3000 rpm ahead!
Overall, we’d like to highlight the fact that the brand is offering a new color for its fans. Initially available in black, the Silent Wings 4 are now available in white. Naturally, two sizes are available: 120 mm and 140 mm.
In addition to these two sizes, there are three variants offering different speed profiles:
- 120 mm PWM: up to 1600 rpm
- 140 mm PWM: up to 1100 rpm
- 120 mm PWM high speed: up to 2500 rpm
- 140 mm PWM high speed: up to 1900 rpm
- Pro 120 mm PWM: up to 3000 rpm
- Pro 140 mm PWM: up to 2400 rpm
Of course, each profile has its own specific use. In PWM, be quiet! indicates that they are ideal for use on cases. The high-speed and Pro versions are intended for cooling watercooling radiators or aircooling heatsinks.
Each fan comes with different sets of silentblocs for tool-free assembly. Note that the Pro model also features silentblocs specially designed for radiator mounting, to prevent air leaks between fan and radiator.
Likewise, the pro model features a speed selection switch with profiles for silence, performance/noise ratio or maximum performance!
Availability is currently set for April 4, with prices officially ranging from €24.90 to €33.90.
Here are the be quiet product sheets!
