Sharkoon REV300: an all-white case selling for €160!
The REV300 is a case offered by Sharkoon since June 2021, however, this was only the black version of the case. Today, the brand announces the arrival of a white version. As a reminder, this was a case featuring a motherboard tray oriented at 90°!
REV300: the case returns in white!
Sharkoon REV300 White
This is a rather imposing model, with dimensions of 238 (W) x 501 (D) x 550 (H) mm and a weight of 10.4 kg.
Inside, the motherboard tray is oriented at 90°. This means that when the graphics card is installed, it will be suspended in a vacuum. Clearance for the graphics card is also generous: 34.5 cm, 33.3 cm with the 90° mounting kit, with ventilation towards the glass. Finally, for the CPU cooler, we have 17.7 cm of free height.
The basic ventilation is quite substantial, featuring four 120 mm aRGB fans. This can be complemented by three 120 mm slots on the front. By default, the fans are mounted at the rear and top.
As for watercooling, compatibility with 360 mm radiators should be assured. But the datasheet is not very precise on the subject.
As for the price, we told you: €159.90 officially. For the moment, retail availability has not been verified, so we’ll have to wait and see… Or fall back on the black model (see comparison above).
Here’s the Sharkon product sheet!
