Sharkoon also announces its SilentStorm BW120 fans!
After announcing its M30 RGB and M30 Black the Sharkoon brand has announced new fans. On the program, we find the SilentStorm BW120 PWM.
Two colors of silentblocks for the SilentStorm BW120 PWM !
Sharkoon SilentStorm BW120 PWM
With its fans, the brand offers us 120 mm mills with a thickness of 25 mm. On its side, the frame is square and black. However, if you want, you can change the color of the silentblocks that land in black … Or in white. Beside that, the blades are nine in number, quite straight and rather flat too. It briefly reminds us of the NF-F12 of Noctua, but a little thinner.
In terms of characteristics, it is a fairly slow fan that will only run from 450 rpm to 1400 rpm. Clearly, we do not expect a noisy fan… Although one can be surprised in this environment. Otherwise, the data sheet mentions an airflow reaching 89.06 m3/h with a static pressure pointing to 1.31 mmH2O.
Finally, we will retain its price rather soft since it is displayed at less than 10 €. Indeed, it will take 8.99 € / piece officially. It remains to be seen how much it will really cost in the shops.
