Seasonic has reworked its Core ATX 3 series of power supplies, making them compliant with several standards, including ATX 3.1 and PCIe 5.1. In short, we’re dealing with a very attractive series of power supplies.
Core ATX 3: Seasonic power supplies updated!
With this series, the brand offers us a range of three power ratings, with 650W, 750W and 850W models. The range also boasts 80+ Gold certification (92% efficiency at 50% load). There’s also fully modular cable management, so you can carefully select the connectors you need and avoid cluttering up the box with unnecessary cables.
The series is compact, with a 14 cm deep casing. So you shouldn’t have any trouble fitting these power supplies into a PC case, even in some ATX-compatible ITX models.
Internally, Seasonic is revamping the internal design of its blocks, opting for a design without internal cables. Instead, we have different PCBs positioned to encourage airflow between components. Speaking of airflow, ventilation is provided by a 120 mm fan. However, the fan is 100% active, so there is no semi-passive mode.
All the necessary electrical protection is also provided. These include the OCP,OPP,OPT, SCP,OVP and UVP.
As for connectors, you’ll find them detailed in the table below:
Finally, all that remains is to talk about the price. These are €129.90 for 850W, €115.90 for 750W and €105.90 for 650W. Availability in Europe is set for the end of December in black and the end of February in white. The warranty is for seven years!
Click here for the Seasonic product sheet!
![[LABO]: AORUS RTX 5080 INFINITY AORUS RTX 5080 Infinity miniature](https://en.overclocking.com/wp-content/medias/sites/4/2026/08/AORUS-RTX-5080-Infinity_main-100x70.jpg)
