RTX 3060 Mini OC: an ultra compact card from Colorful!
After ASRock it’s now Colorful’s turn to launch an ultra-compact graphics card. Indeed, the Chinese brand announces its iGame RTX 3060 Mini OC, a model of 18 cm in length. In short, an interesting model for those who want to start assembling an ITX configuration for example!
RTX 3060 Mini OC: 18.2 cm long and overclocked from the factory!
Colorful iGame RTX 3060 Mini OC
With this new model, Colorful offers us an ultra-compact card as evidenced by its 18.2 cm length. In fact, this model will barely exceed an ITX motherboard (17 x 17 cm).
Nevertheless, the heatsink is enormously simplified since there is only one block of aluminum fins. These are also crossed by four copper heat pipes of 6 mm each. Finally, a small fan dominates the whole. Moreover, it has a semi-passive operating mode.
Despite this ultra-small size, Colorful still performs factory overclocking, which is admittedly timid, but it is definitely present. Thus the GPU boost goes from 1777 MHz for the Founder Edition to 1792 MHz via the “One-Key OC” button on the card’s bracket.
By the way, the connectivity let’s talk about it since this model has three DisplayPort outputs and an HDMI. Finally, the power supply will go through a single PCIe 8-pin.
Here is the Colorful datasheet!
