Rebel C70 RGB, a Sharkoon case with a wooden front panel!
New case from Sharkoon: the Rebel C70 RGB. This new case has a very special feature: a wooden front panel. Coupled with Sharkoon’s usual prices, this makes for an original reference at an affordable price… At least on paper.
Rebel C70 RGB: a new case with a wooden front panel!
With this new case, we’re dealing with a reference in mid-tower format. Weighing in at 8.3 kg, it measures 230 (W) x 479 (D) x 495 (H) mm.
Inside, you’ll find the usual array of ATX-format motherboard support. The graphics card benefits from 40 cm of clearance. The CPU cooler is 165 mm high, while the power supply is 270 mm deep.
Standard ventilation is provided by four 120 mm RGB fans, three at the front and one at the rear. As an option, three additional slots are available at the top and on the side of the motherboard. As for watercooling, although the brand’s data sheet is not very clear, there’s no reason why we couldn’t fit a 360 mm radiator.
Finally, we’d like to mention the two versions on offer: G with a glass side panel and M with a mesh panel.
As for prices, expect to pay around €120 for both variants at Amazon or Alternate!
Here’s the Sharkoon product sheet!
