ProSiphon Titan: a pumpless AIO from IceGiant!
Today, we’re going to tell you about a new product from IceGiant, a brand that has already made a name for itself in the past with its ProSiphon Elite. As a reminder, this was a cooling system based on the phase-change principle. The heatsink adopts a shape comparable to that of an AIO, but without a pump. Today, the brand returns with the ProSiphon Titan, a heatsink based on the same principle, this time in the form of a 360 mm AIO, but without a pump!
ProSiphon Titan: a pumpless phase-change AIO in 360 mm!
IceGiant ProSiphon Titan 360As mentioned above, this kit is based on the phase-change principle. Internally, we find a liquid that evaporates at low temperature, carrying the heat to the condenser, which acts as a heat exchanger. When cooled by fans in the aluminum condenser, the vapour returns in liquid form to the copper base in contact with the CPU, cooling it in the process in a perpetual cycle.
This time, the brand adopts a more conventionalAIO shape, as can be seen with the condenser on one side, topped by three fans, and the cold plate on the other. Like an AIO, these two elements are connected by a set of pipes. However, apart from the fans, there are no mechanical elements like a pump or anything else – it’s 100% passive.
IceGiant ProSiphon Titan-tr360
This absence of mechanical elements means that the brand is so confident in the reliability of its product that it doesn’t hesitate to offer a lifetime warranty. Nevertheless, the fans are guaranteed for 6 years. At the same time, they are P12s adapted to IceGiant’s specifications. It remains to be seen how fast they will actually work. On the ProSiphon Elite, the four fans ran at 2300 rpm.
For prices, you’ll need to reckon with around €415 and €592 for the Threadripper version. No, it’s not cheap. On the other hand, if these products live up to their promise, you’ve got heatsinks that are simply unbreakable!
