Pro DP10, a series of mini-PCs from MSI with 1.1l volume!
MSI launches a whole new series of mini-PCs with its Pro DP10 Series. They are ultra-compact machines oriented to business/office with a very small footprint of only 1.1l.
Pro DP10 Series: machines that can be equipped with Core i7!
MSI Pro DP10
We start with the dimensions of these PCs which are very compact. Indeed, the machine measures 34.48 (W) x 178.82 (D) x 179 (H) mm, all for a volume of only 1.1l. In addition, if desired, it can be mounted on a VESA support in 75×75 mm.
Internally, the brand offers three CPUs, so we can choose between the Core i7-1360P, a Core i5-1340P and a Core i3-1315P. The memory part provides two SO-DIMM RAM slots in DDR4 for a total of 64 GB of memory. As for storage, we have a 2.5″ slot as well as two M.2.
The connectivity is rather complete since it highlights a USB-C 3.2 Gen2 and three USB-A 3.2 Gen1. A headset jack is also present and it is driven by a Realtek ALC256 audio chip. At the back, we find HDMI 2.0b, DisplayPort 1.4 and VGA video outputs, which can be switched to COM port. We also have a Thunderbolt 4 in the form of a USB-C, two USB-A 3.2 Gen1 and an RJ45 socket. Note that the network part is supported by a Realtek RTL8125BG-CG chip. Similarly, WiFi is available via Intel AC3168 as well as Bluetooth 5.3.
This way to the MSI datasheet!
