PP07E White: white cable extensions signed Silverstone!
Small novelty at Silverstone which, in addition to its power supplies, also offers cable extensions. In the program, we find the PP07E White, extensions sheathed strand by strand, all in white.
PP07E White: white extensions at Silverstone!
Silverstone PP07E WhiteThe brand offers new cable extensions that complete its catalog. As you can see, they are entirely white, whether it is the sheath or the connector itself. Regarding connectors, Silverstone offers an extension forATX 24 pins, one forEPS12V and one for PCIe 6+2 pins. For the length, all this little world shows 30 cm … Which can be problematic when wiring. Yes, let’s not forget that it is an extension, so it adds length to manage. However, the advantage is the universal compatibility with our power supplies. Here, no hesitation to have, especially since the combs are also provided. We will have strands well aligned with each other for a perfect result! Finally, a word about materials since we find multi-stranded copper cables of 0.08 mm. As for the sheath, it is made of high-density nylon and should therefore last over time. Finally, Silverstone announces a resistance to high temperatures. For the moment, no price is known. However, based on the prices of Alternate however, based on the prices of the 24-pinATX, the price should be around ~15 € – 16 € against a dozen euros for PCIe. Finally, for theEPS12V, we can expect a little less than ten euros.
Here are the technical data sheets of Silverstone!
