Phanteks announces its compact ATX case, the G300A!
We return to the field of PC cases with the new announcement of Phanteks which unveils a new reference. Indeed, the company offers us its G300A, a new compact and affordable model. Moreover, it comes in several fan configurations!
G300A: the choice between one or three fans!
Phanteks G300AWith this new case, the brand offers us a rather compact medium tower reference. It displays 200 (W) x 400 (D) x 465 (H) mm. The weight is also contained with 5.56 kg on the scale.
Inside, we find a compatibility with ATX motherboards at the maximum. Otherwise, for the other components, we have up to 390 mm for the graphics card, 162 mm for the cpu cooler and up to 220 mm for the power supply.
Basically, the case offers a choice between two configurations for its fans. Indeed, you can choose between the model with a pre-installed aRGB fan, or the one with three fans mounted on the front panel. It goes without saying that the more fans there are, the higher the bill.
As for the watercooling radiators, the case will be able to accommodate 360mm models on the front against a 240mm on the top. Be careful, as this will reduce the space available for the graphics card.
Finally, for the storage part, we find only a 3.5″ slot. However, Phanteks gives pride of place to 2.5″ units with three dedicated slots.
The bill, as we said, is not very high since it varies between $69.99 and $79.99 depending on whether you have one or three fans.
Here is the Phanteks datasheet !
