Phanteks announces a new R220C pump/tank combo!
Small novelty at Phanteks which completes its catalog of components for custom watercooling. Indeed, the brand launches a new tank/pump combo with its R220C.
R220C : a pump/tank combo with integrated DDC pump !
Phanteks R220C
With this set, the brand launches a combo to integrate into your custom loop. For this, we find a total of four threads in G1/4″, two on the bottom and on the side of the tank. For the filling, a fill port is also present on the top.
As for the dimensions, this model displays 80 (W) x 34 (D) x 220 (H) mm. The construction is based on an acrylic body with steel for the mounting system. The capacity is 200 ml with a weight of 437 g.
Regarding the assembly, in the box we have everything necessary to fix the combo on a watercooling radiator in 120 mm or 140 mm and it can be placed vertically or horizontally.
Phanteks R220C
Finally, for the price, we will have to count a nice bill of 199,90 €. Note that at this price the DDC pump with its cover is provided and pre-mounted. Note also that a LED strip with everything necessary for the connection is also part of the game … This is the little bonus.
Here is the Phanteks datasheet !
