PC-011 Vision: a case with panoramic view from Lian Li
This morning we learn that Lian Li is offering a new version of its flagship case, the PC-011 Vision. This version clearly focuses on component vision, with a total of three glass panels. These are found on the front, side and top.
PC-011 Vision: three glass panels, no front pillar, unobstructed view!
Lian Li PC-011 Vision
This new model features a rather imposing case measuring 304 (W) x 480 (D) x 464.5 (H) mm. The choice of materials includes steel for the chassis, aluminum and tempered glass. The design, of course, is sober, all the more so as it offers a clear view of the configuration. To hold the various panels together, there is no central pillar.
Internally, the brand continues to opt for a compartmentalized design, especially as the motherboard tray is removable. It can also be adjusted in height to accommodate a 240 mm watercooling radiator at the rear. Otherwise, E-ATX motherboard support remains unchanged. The rest of component compatibility is not particularly highlighted.
In terms of ventilation, eight 120 mm fans can be fitted if required. As for watercooling, this model will accept 360 mm radiators without a hitch.
Otherwise, for storage, we have a total of three 2.5″ slots, complemented by two others in 3.5″/2.5″.
As for pricing, the bill comes in at £139.98 in black versus £144.95 in white.
Here’s the Lian Li product sheet!
