P14 PWM PST aRGB: 140mm Arctic fans go RGB!
A new fan arrives at Arctic with the P14 PWM PST aRGB. You will have understood, the luminous lighting lands on the 140 mm mills of the brand. Moreover, we can even enjoy a semi-passive mode.
P14 PWM PST aRGB: Arctic’s fans are bright and semi-passive!
Arctic P14 PWM PST aRGBWith this 140mm version, we find the classic shape of the brand’s P fans. Thus, we still find our five blades that are very elongated and stretched. Like the P12 we tested here, they are also connected to each other by a hoop at their end.
Of course, RGB lighting is part of the package. For this, there are a number of LEDs on the fan motor. These may or may not be addressable depending on the model you choose.
In terms of technical characteristics, this P14 benefits from a PWM type power supply. Its rotation range extends from 0 RPM to 1900 RPM with a semi-passive mode up to 10% PWM signal. At full speed, the airflow will reach 68.9 CFM and the static pressure will be 2.00 mmH2O.
Finally, concerning the connectivity, we find a double male/female fan plug. The objective is to be able to connect the fans in series in order to limit the number of sockets occupied on the motherboard. Moreover, this will allow a better management of the ventilation by creating groups of fans.
We finish with the selling price which will be 43.99 € for the aRGB models in a pack of three and 19.99 € per unit. The RGB version (non-addressable diodes) will cost €39.99 (€52.99 with controller) in a pack of three and €18.99 individually.
Go here and here for Arctic’s data sheets!
