NZXT offers its H5 Flow RGB and H7 Flow RGB enclosures
NZXT offers two new versions of its PC cases with the H5 Flow RGB and H7 Flow RGB models. Until now, these versions did not exist, the luminous lighting was reserved for the Elite versions of cases!
H5 Flow RGB and H7 Flow RGB: the new versions of NZXT!
H5 Flow RGB
The small H5 with its perforated grid and RGB fans
With these new cases, we find, vulgarly, Hx Flow equipped with bright fans. As a reminder, these models at their initial release did not have a lighting system. It is now done via luminous fans.
Thus, the H5 now has a total of five fans, including two with RGB lighting. Indeed, we find two F140 RGB Core in the front, an F120 without lighting in the back and a small F120, still without lighting, in the bottom.
On the side of the H7, there are three 140 mm luminous mills that appear behind the front panel and a 140 mm without lighting at the back.
H7 Flow RGB
The H7 with its perforated grille and RGB fans
With these new configurations, we have cases arriving with more fans than their non-RGB Flow counterparts. In the case of the H5, we have a more complete ventilation than its Elite variant.
As for pricing, the H5 Flow RGB is priced at $119.99 or 129,99 € against $159.99 or 164,99 € for the H7 Flow RGB. Otherwise, there will be no change in features.
