NZXT introduces its 1500W C1500 power supply!
NZXT has announced its C1500 power supply, a truly top-of-the-range power supply. With a power supply like this, you’re all set to power any consumer configuration in the best possible conditions!
C1500: big power supply from NZXT!
NZXT C1500 PlatinumWhat we have here is an imposing 180 mm deep power supply. At the same time, it’s got what it takes to pack in 1500W of power.
In terms of certification, we’ll be mentioning the 80+ Platinum and Cybernetics Titanium certificates for efficiency. Alongside this, we find a fully modular cable management.
Internally, we find quality components with, in particular, Japanese 105°C capacitors. Ventilation is managed by a 140 mm fan with magnetic levitation bearings.
As far as the electrical side is concerned, the unit complies with ATX 3.1 and PCIe 5.1 standards. As for protection, we’ve got everything you need: OVP, UVP, SCP, OTP, OPP and OCP.
In terms of connectors, we’ve got everything we need, with two EPS12V CPUs, six PCIe 6 2-pin connectors, twelve SATA connectors, four Molex connectors, and above all, two 12V-2×6 connectors for NVIDIA’s RTX 40s.
As for the price, it’s not cheap per se, with a price tag of €330 and a 10-year warranty!
Click here for the NZXT product sheet!
