Noctua launches NH-L9a-AM5 for Ryzen 7000!
Noctua offers a new variant of its ultra-compact cooling unit for ITX platforms. Indeed, the brand offers its NH-L9a-AM5, which is available in black or Chromax.Black for those who know it.
NH-L9a-AM5 : a mini cpu cooler for Ryzen 7000 !
NH-L9a-AM5With the launch of the Ryzen processors in 65W of consumption, Noctua decided to propose an AM5 version of its NH-L9a.
What does it change? Well, not much. Compared to the AM4 version, this model offers the same dimensions: 114 (W) x 92 (D) x 37 (H) mm with the fan. Likewise, there is no change in the weight with its 465g with the fan.
The radiator offers a structure with a nickel-plated copper base and two copper heat pipes. The same goes for the fan which is still an NF-A9x14 HS-PWM operating at up to 2500 RPM. At full speed, the air flow will be 57.5 m3/h.
In fact, what Noctua offers here is a model optimized for the AM5 socket. By the way, if you want, you can get this AM5 version and ask for an AM4 mounting set to install it on older generation motherboards.
As for the price, it will cost 49,90 € for the brown/beige version against 59,90 € for the Chromax.black version. A price identical to the AM4 version, which is good news!
Here and there the technical data sheets of Noctua !
