Noctua launches its NA-FG1 fan grills!
Noctua is launching a new accessory that joins its catalog. This time, it is about fan grills. The latter is available for many fan sizes, all in packs of two or five!
NA-FG1: fan grills signed Noctua!
Noctua NA-FG1On the menu, the Austrian brand offers us its new fan grills. These are round and not flat. The reason behind this is to improve the acoustic performance of fans… Or at least, not to degrade them with flat grilles.
Moreover, these grilles are available in a variety of sizes. There will be some for more or less all sizes. Indeed, fans in 40, 50, 60, 70, 80, 92, 120, 140 and 200 mm are concerned. In addition, they are offered in sets of two or five, perfect for garnishing your entire PC.
For the assembly, several choices are offered to us. Either we screw them directly on the fans, or we use push-pin nipples without tools. Two sizes of nipples are offered, one allowing the grille to “stick” to the fan, the other offering a slight offset.
We finish with the prices which are 12.90 € the set of two against 19.90 € the set of five. They will concern the grids whose sizes are between 40 mm and 92 mm included. Then we go to 14.90 € (x2) and 24.90 € (x5) for those in 120 mm and 140 mm. Finally, we finish at 19,90 € (x2) and 29,90 € (x5) for those in 200 mm!
Here are Noctua’s data sheets!
