Earlier this morning, we told you about the new roadmap of Noctua. For this second quarter, the brand planned the arrival of a fan hub, the NA-FH1, which is now available. Indeed, the brand lifts the veil of its hub.
NA-FH1: Noctua announces its fan hub!
On the program, we find a hub powered by a SATA plug capable of providing up to 54W of power. On the other side, we have our board with eight fan plugs in four PWM pins. The latter is also well equipped in terms of protection since it has safety devices against overcurrent or short circuits. Finally, even for the speed reading, the circuit is improved so that the motherboard can read the fan speed correctly.
Of course, everything can be connected to the motherboard via a four-pin PWM socket. This will allow the signal to be applied to all the fans connected to the hub. Note that a 30 cm extension cable is provided in the bundle.
The installation in a case is done simply via a system of magnets. Like that, no need for a sticky patch or a screwdriver.
Well, the only problem in the story: the selling price, rather high of 34.90 €. However, it is already available at Amazon.
