The NF-A4x10 24V is the latest addition to the Noctua catalog. This is a very small fan designed for the 3D printing industry. It will be particularly useful for cooling printer nozzles.
NF-A4x10 24V: Noctua in your 3D printer!
Noctua offers us a fan that’s absolutely mini, thanks to its 40 mm square frame. What’s more, it’s only 10 mm thick. However, this doesn’t prevent the fan from having rubberized silenblocks to reduce vibrations when it’s running, oh no!
In terms of characteristics, this is a 24V-powered mill with a PWM signal. With a maximum speed of 5,000 rpm, it’s ready to go fast. Finally, the airflow is 5.24 CFM, while static pressure rises to 1.95 mmH2O.
Finally, to connect this fan to your 3D printer, the brand supplies all kinds of adapters. Included in the package is an NA-AC9 terminating in a 2.5 mm JST XHP-2 connector for connection to a 2-pin header. Otherwise, an OmniJoin adapter is offered, as are the NA-EC1 30 cm extension and the NA-RC8 L.N.A adapter.
In the end, this is a fairly exclusive fan, but one that will satisfy 3D printing users… All the more so as this isn’t the first time the brand’s fans have been tinkered with. Price: €15.90, available immediately!
Here’s the Noctua product sheet!
