Nebula VGA: a Bitspower waterblock for the RX 7900 XTX
The rather discreet brand Bitspower announces the arrival of a new waterblock. With its Nebula VGA, the brand attacks AMD cards and more precisely the RX 7900 XTX reference. In short, let’s see what it offers!
Nebula VGA: Bitspower attacks the RX 7900 XTX of AMD!
Bitspower Nebula VGAFor the occasion, Bitspower announces the arrival of a new block measuring 270 (W) x 135.5 (D) x 30.7 (H) mm. Of course, the base material is still copper, which is nickel-plated and has a mirror finish. Finally, for the upper part, we find acrylic will act as RGB diffuser … Because yes, an aRGB lighting system is present.
Of course, this block is full cover and will actively cool the GPU, memory and power stages of the card. The thermal pads are pre-applied and all that remains is to remove the protective plastic before placing the block on the board. For the connection to the rest of your custom loop, we find four standard G1/4″ threads.
Finally, a backplate comes with the block. At the same time, for $250 (7500 TWD), this is the kind of attention we like!
Here is the Bitspower datasheet !
