N2: a mini-ITX NAS enclosure from Jonsbo!
Jonsbo continues to propose its novelties and this time, the brand announces its small N2. It is a small case, ITX format, which is intended, this time, to accommodate a NAS type configuration!
N2: an ITX case for NAS from Jonsbo!
Jonsbo N2 With the N2, the Chinese brand offers us a reference, necessarily compact, which measures 222.5 (W) x 222.5 (D) x 224 (H) mm. The weight is also very light: 2.9 kg.
Inside, we have room for a motherboard in mini-ITX format. For the graphics card, it will not be necessary to be greedy since this model allows the installation of a single slot card in low profile format of 197 mm long. Finally, for the cooler, you should opt for a heatsink less than or equal to 65 mm in height.
Finally, it is on the storage part that this model stands out with no less than five 3.5″ slots. As a bonus, we have one last 2.5″ slot for an SSD. If you are looking for a case to build a NAS, this little N2 is clearly a model to watch out for. Beware also of the size of the power supply limited to SFX format only.
All that remains is to know the selling price of this model which is, for the moment, unknown!
This way to the Jonsbo datasheet !
