MSI introduces its AIO MAG CoreLiquid I!
MSI presents new all-in-one watercooling kits with its MAG CoreLiquid I series. The range comes in two radiator sizes, 240 mm and 360 mm, in black or white!
MAG CoreLiquid I: new MSI AIOs in black or white!
MSI MAG Coreliquid IWhat we have here is two all-in-one watercooling kits with 240 mm and 360 mm radiators. They feature an aluminium build and a standard thickness of 27 mm.
The pump is housed in an attractive cover with a mirror finish and infinite depth effect. A luminous light is fitted to highlight this part. Otherwise, we note that the Intel/AMD mounting arms are fitted as standard, so there’s no need to change them to switch from one platform to another.
On the ventilation side, there are two or three 120mm fans. In terms of speed, we know that they will operate at a maximum of 2350 rpm and generate 70.7 CFM of airflow at full speed. MSI also says that they will come pre-mounted on the radiator as standard. What’s more, the number of cables has been reduced to make installation easier: one cable for every three fans.
As for the price, there’s talk of a mid-August launch at a price of $94, presumably for the 360 mm model. If that’s the case, it’s a good thing, as it means we’ll have a liquid cooling system at a very aggressive price!
Read the MSI product sheets here and here !
