MS31 and MS21 airflow enclosures from Enermax
Today we learn that the Enermax brand is announcing two new enclosures. The company is unveiling its MS31 and MS21 models, two airflow-oriented models sharing the same design. What sets them apart is their size, with one model designed for ATX motherboards and the other for micro-ATX boards!
MS31 and MS21, Enermax airflow enclosures!
Enermax MS31 et MS21As you can see, the brand will be offering its cases in black and white. However, the asymmetrical design of the perforated mesh front panel is particularly noteworthy. This should ensure good airflow inside the machine.
Otherwise, the MS31 is compatible with E-ATX motherboards, while the S21 will have to make do with micro-ATX models.
Inevitably, the S21’s capacity to accommodate components will be more limited than that of the 31:
  • CPU fan: 162 mm
  • Watercooling radiator: up to 360 mm vs. 420 mm
  • Graphics card: 365 mm vs. 410 mm
  • Expansion slot: 5 vs. 7 for
In terms of dimensions, there are also differences: the MS21 measures 210 (W) x 370 (D) x 435 (H) mm, while the largest model measures 210 (W) x 415 (D) x 470 (H) mm.
When it comes to price, you don’t have to look far. The larger model costs €80, while the smaller model costs €70.
Enermax fact sheets here and here !
