MinisForum announces a Venus UM773 PC with Ryzen 7 7735HS
MinisForum continues to offer us mini PCs that are always more compact and powerful. This time, for its Venus UM773, the brand opts for the new AMD mobile chips with a Ryzen 7 7735HS.
UM773: a mini PC with Ryzen 7 7735HS!
MinisForum Venus UM773
Of course, the MinisForum machine is still very compact… Even if the dimensions are not known…
In any case, the basic machine has a Ryzen 7 7735HS, a model with a total of 8 cores and 16 threads. Basically, everything runs at 3.2 GHz with a boost that can reach 4.75 GHz. Finally, we have a configurable TDP between 35W and 54W.
On the graphics side, of course, we have the right to an iGPU, a RADEON 680M. A small graphics part with 768 stream processors, 48 TMU and 32 ROP. Of course, it should not be confused with the RX 6800M which is a mobile GPU dedicated more robust with 2560 stream processors, 160 TMU and 64 ROP.
As always with the brand, we have the right to several configurations:
  • Barebone: without RAM or storage
  • 16 GB RAM + 512 GB SSD
  • 32 GB RAM + 512 GB SSD
  • 32 GB RAM + 1 TB SSD
  • 64 GB RAM + 1 TB SSD
Of course, the configuration will have a direct impact on the price, which ranges from €479.00 in barebone to $789 with 64GB of RAM and 1TB of SSD. Finally, the cooling is quite efficient with a blower fan composed of 120 blades and liquid metal as TIM.
