Meshroom S : Ssupd’s case at 179,90 € on Caseking !
Last August, we learned that Ssupd was launching a new case on the market. Indeed, the brand announced its Meshroom S, a compact case, ITX type, entirely in mesh. This last one has the particularity to offer an ATX motherboard support despite its format!
Meshroom S : a price of about 180 € at Caseking.de!
Ssupd Meshroom S
An ATX motherboard and an AIO installed!
As a reminder, the case of Ssupd displays compact dimensions since they are 167 (W) x 247 (D) x 362 (H) mm. The weight is also very light since it is only 3.7 kg. At the same time, this model is made of a steel structure and mesh panels.
Inside we have room for the installation of motherboards in ATX, µATX and mini-ITX format. The graphics card will be installed vertically, behind the motherboard tray thanks to an optional PCIe riser. The latter benefits from an important clearance of 336 mm on three slots maximum. The cooling part will be more limited with only 74 mm height. Via an adapter, it will be possible to install a power supply in ATX format.
Depending on the configuration, it will be possible to opt for liquid cooling. The case claims to be compatible with 280mm watercooling radiators. The rest of the ventilation can accommodate up to five fans in 120 mm.
Ssupd Meshroom S All this to say that the case is displayed at Caseking Germany at a price around 180 € with the 14 cm PCIe 4 .0 riser . We appreciate the many colors offered: black, gray, green and blue. Also, glass side panels are available for about 30 euros, as well as tinted mesh panels. The only thing left is the availability date: November 25 according to the German retailer.
Here is the datasheet of Ssupd!
