Cooler Master has unveiled a new case: the MasterFrame 400 Mesh Gold Limited Edition. With this new case, the brand highlights a 3D mesh front panel and a striking gold color. Unfortunately, there won’t be enough for everyone, as this is a limited edition of just 999 units worldwide. If you want one, you’ll have to hurry!
MasterFrame 400 Mesh Gold Limited Edition: a compact, gold-colored case!Â
A compact model with great potential!
With this case, Cooler Master offers a compact model measuring 261 (W) x 471 (D) x 373.8 (H) mm. As you can see, its front panel features a 3Dmesh design, which should allow components to breathe properly. In fact, this design is familiar in the industry, as it uses the same texture found on NVIDIA’s DGX Spark.
Internally, the chassis can accommodate micro-ATX and mini-ITX motherboards. CPU coolers have plenty of room to work with, thanks to 190 mm of vertical clearance. The same goes for the graphics card, which can be up to 390 mm long. As for the power supply, however, it’s limited to 160 mm in depth, and must be either ATX or SFX format.
Cooling can be comprehensive, with up to seven 120 mm fan slots. This number drops to five with 140 mm fans and to four with 180/200 mm fans. As for water cooling, 360 mm radiators can be mounted at the top.
Based on the FreeForm 2.0 concept, the case can be installed vertically or horizontally. This way, you can set up your system however you like.
Only 999 units available!Â
If this case has caught your eye, you’ll need to hurry to place your order, as production is limited to just 999 units, each with a serial number displayed on the control panel. As for the price, it’s expected to be around $180.
Check out the product page on Cooler Master’s website!
