MAG301 CR3 : a 200 Hz WFHD display from MSI!
New screen signed MSI which proposes us an Optix MAG301 CR3. It is a curved reference displaying a 21:9 resolution… Not to mention its high refresh rate and low latency making it a responsive monitor!
MAG301 CR3 : an ultra responsive WFHD screen !
MSI Optix MAG301 CR3 On the program, we find a rather imposing monitor with its 29.5″ VA panel. The latter displays a resolution of 2560 x 1080, a 21:9 format. Moreover, MSI offers us a curved monitor with a curvature radius of 1500R, ideal with this format.
In terms of responsiveness, we clearly have nothing to complain about since this model offers a refresh rate of 200 Hz. The latency is not left out either with 1 ms MPRT. In addition, to reduce the effects of tearing, we find a FreeSync Premium compatibility.
In terms of display, this model highlights a brightness of 300 nits with a contrast ratio of 3000:1. It can also display up to 1.07 billion colors while covering 110% of the sRGB spectrum and 90% of the DCI-P3 range. Finally, the vertical and horizontal viewing angles are 178 °.
This reference also has a small RGB light and an adjustable foot. The connectivity consists of a DisplayPort 1.2a input (200 Hz), a HDMI 2.0b (180 Hz) and a USB type C acting as DisplayPort (200 Hz). Let’s not forget to mention the integrated USB HUB and the 3.5 mm jack.
For the moment, no price is known.
Here is the technical data sheet of MSI !
