MAG CoreLiquid B: new MSI entry-level AIO!
New series of watercooling kits to arrive at MSI with the MAG CoreLiquid B. A new series positioning itself on the entry level sector of the brand by proposing two kits. The first model will be in 120 mm while the second will have a 240 mm radiator!
MAG CoreLiquid B : two AIO in 120 mm and 240 mm !
MSI MAG CoreLiquid B240
The program includes two new watercooling kits. Despite the different sizes, 120 mm and 240 mm as a reminder, the thickness of the radiator will be the same in both cases: 27 mm, the same for the aluminum construction.
Like the MAG CoreLiquid C240 (test available here), the pump of these models is located in the radiator. It has a 6-pole motor and will work up to 4200 RPM. However, its characteristics are not known. We only know that the logo will be able to be oriented on 360° in order to be displayed in the right direction.
The ventilation will be provided by one or two fans in 120 mm. These fans have a speed between 500 RPM and 2000 RPM. At full speed, the air flow will reach 78.73 CFM, but the static pressure is unknown. In addition, we note that they have an RGB lighting.
MSI MAG CoreLiquid B120
Finally, you should know that the kits can be installed on a wide range of platforms, including LGA-1700. However, the TR4 is not included.
Currently, we do not yet know the selling price, we will have to wait a little longer…
Here and there are the technical data sheets of MSI !
