LP Series: DeepCool AIOs with Matrix display
A new batch of all-in-one cooling kits from DeepCool, with its LP Series. These kits feature a ‘Matrix’ digital display. As with the Ryuo IIIs, this is simply a grid of diodes that can be lit independently of each other to display whatever you want.
LP Series: AIOs with a Matrix display!
DeepCool LP SeriesThe brand’s programme includes kits available in two radiator sizes, with 360 and 240 mm AIOs. As for the colours, they will initially be available in black. White versions will follow at a later date.
As can be seen, the kits take up the characteristic shapes of the brand’s AIOs. The special feature of the pump is that it displays a grid of 14×14 diodes that can be lit independently to generate your own pixel art, etc., etc.. In any case, this is a fifth-generation pump operating at up to 3400 rpm. Unfortunately, its other characteristics are still unknown.
Out of the box, the fans will be fitted as standard to the radiator, which will speed up the assembly process. However, the brand’s press release does not give us their characteristics. All we know is that they use an 8-pin connector for simplified cable management(PWM RGB).
In terms of price, expect to pay $132 for a 240mm model, compared with $154 for a 360mm model, which makes them very affordable compared with the competition. As for availability, you’ll have to wait until January 2025 for the black versions and April 2025 for the white kits.
