Light Loop IO LCD: New Water-Cooling Kits from be quiet!
The German brand be quiet! is also beginning to incorporate LCD screens into its water-cooling kits with the unveiling of its AIO Light Loop IO LCD. These units feature prominent RGB lighting on the fans and the pump cover, while also incorporating a small screen. Of course, thanks to the dedicated software, you’ll be able to customize this display or select the system information you want to keep an eye on.
Light Loop IO LCD: be quiet! AIOs with a display!
Available in 240- and 360-mm models!
be quiet! Light Loop IO LCD
At this time, the full technical specifications are not yet known. However, we do know that these AIOs are available in 240- and 360-mm sizes. The radiator appears to have a high-quality finish, featuring a square aluminum block with no visible screws or rivets. If there are no changes from the current Light Loop models, it should be 27 mm thick.
We know that be quiet! will use 120 mm Light Wings LX PWM fans. These fans support daisy-chain connections and feature nine illuminated blades. According to their spec sheet, they spin at up to 2,100 RPM and generate an airflow of 61.8 CFM as well as a static pressure of 2.51 mmHâ‚‚O.
But the most interesting feature is the pump itself, which includes a small 2.1-inch LCD screen with an IPS panel. This screen has a resolution of 480 × 480 pixels and a brightness of 500 nits. An RGB light ring surrounds the screen. In any case, this screen will allow you to display custom backgrounds while selecting which system data to monitor!
Prices:
As for retail prices, the 240 mm model is priced at €204.90, while the 360 mm model costs €229.90. As for the white versions, simply add a €5 surcharge to the prices already listed. The warranty is for three years, and the launch is scheduled for August 11.
Check out the product pages for be quiet! here.
