Light Loop: even more RGB from be quiet! !
On the be quiet! front, we have a new series of AIO watercooling kits with a greater emphasis on RGB. With its Light Loop range, the lights are everywhere: on the fans and the pump, with a particular focus on the pump cover!
Light Loop: do you like RGB?
be quiet! Light Loop
The brand is offering four variations of its series, with 240 mm and 360 mm kits. Two colours are available, white and black.
As far as the kits themselves are concerned, they are fairly classic, with 27mm-thick aluminium radiators. However, we note that the finish is improving, with the presence of striations on the sides in particular.
As for the pump, the new translucent cover is designed to diffuse as much aRGB light as possible. Coupled with the Light Wings LX 120 fans, the kits can contain up to 64 diodes. What’s more, to manage all these more easily, the brand offers a hub that can concentrate up to six devices.
Prices have been announced, ranging from €134.90 for the 240mm black model to €164.90 for the 360mm white. The white versions are generally €10 more expensive due to lower production volumes. Finally, availability is set for September 17th.
Here are the be quiet! product sheets
