Leadex VI Platinum Pro: new power supplies from SuperFlower!
On the SuperFlower side, we will note the appearance of two new power supplies. They belong to the Leadex VI Platinum Pro series and have a power of 850W and 1000W.
Leadex VI Platinum Pro: two high power supplies!
SuperFlower Leadex VI Platinum ProFor the moment it is difficult to be exhaustive about these two power supplies. Indeed, the brand has not yet put online the data sheets of these two references. However, we can tell you that there are two powers: 850W and 1000W.
In any case, they are rather compact blocks with only 15 cm depth. However, they will not be light because it is about 1,85 kg for the 850W. The 1kW model will be a bit heavier: 1.9 kg.
On the cooling side, we can count on a 120mm fan powered by a PWM signal. Two modes of operation are available: Auto and Eco, a semi-passive mode basically.
At the electrical level, we have the right to 100% Japanese capacitor with a number of protections. In the batch, we find the OVP, the OCP, the SCP, the UVP, the OTP, etc. Finally, we find a nice certification with 80+ Platinum.
At the moment, we have no idea of the price or availability. However, we know that the warranty is 5 years.
