Lancool 207: a new model from Lian Li!
A new case from Lian Li, announcing the Lancool 207. This is a fairly compact reference with dimensions close to those of a micro-ATX model. Finally, given the numerous openings, it should offer good ventilation!
Lancool 207, the latest from Lian Li!
Lian Li Lancool 207In terms of dimensions, the case is very compact at 219 (W) x 455.6 (D) x 450 (H) mm. However, internally there’s plenty of space for an ATX motherboard. As for the rest of the components, you’ll be able to install :
  • 410 mm graphics card
  • A 167 mm high CPU cooling unit
  • A 160 mm power supply
This model comes with four fans as standard. While it looks obvious that there are two 140mm aRGB models on the front panel, the other two are more difficult to spot. They are fitted between the motherboard slot and the power supply slot, and both are 120mm models. If required, the case offers four other 120 mm slots with which you can increase the number of fans. On the watercooling side, 360/280 mm radiators can be fitted without any problem.
Otherwise, this case has a rather original layout, with the power supply installed transversely across the front of the case. There will therefore be an extension lead to connect the power supply internally. Velcro strips are also provided to make wiring easier.
For the moment, the price has not been announced, although it is listed at $120.99 on the cipc.com website.
