On the KFA2 side, we have two new graphics cards, the new RTX 4070 Super Ex. These cards come in two colors: white and pink for a more girly configuration!
KFA2: RTX 4070 Super Ex in pink and white!
The program features boards equipped with a three-fan cooling system. As you can see, the middle one is bigger than the other two, while the whole unit benefits from aRGB lighting, which can be controlled via a mobile application.
As for space, you’ll need a little room in your case. While the card occupies a little more than two slots in a PC case, its length can be problematic, depending on the case reference. In fact, you’ll need a clearance of at least 34 cm in length.
Otherwise, these models display boost frequencies of 2565 MHz, so we’re dealing with factory overclocked frequencies (2475 MHz reference). Using Xtreme Tuner Plus software, you can switch to “1-Click OC” with frequencies up to 2580 MHz.
Finally, the power supply is based on a 12VHPWR connector, with a 2×8 pin -> 12VHPWR adapter supplied in the box.
As for price, expect to pay €679, €20 more than for the black model.
KFA2 product sheets here and here !
