KFA2 announces a small RTX 3050 6 GB Ex!
KFA2 announces a new graphics card. Unfortunately, it’s not a new nugget, but a small entry-level card. The brand unveils its small RTX 3050 6 Go EX, a compact model with two fans!
RTX 3050 6 Go EX, the KFA2 model:
KFA2 RTX 3050 6 Go EXWith this card, KFA2 offers us a compact model that occupies just two slots in a case. Likewise, the card’s length is not excessive, at 224 mm. It should fit into a good number of cases, even ITX ones.
Given the composition of the GPU, the cooling system isn’t the most elaborate either. In addition to the two fans, there’s a machined aluminum radiator, but no heat pipes. However, to cool a GPU with a TDP of just 70W, nothing more is needed.
As for frequencies, by default, this model will operate at reference frequencies, with a boost to 1470 MHz. However, via the Xtreme Tuner Plus software, we find the 1-Click OC function enabling us to boost frequencies to 1485 MHz.
For the moment, the selling price is unknown, but it’s reasonable to assume that it will be similar to that of the low-profile models from Gigabyte and MSI!
Here’s the KFA2 product sheet!
