Jonsbo N4, a NAS case made of real wood!
New cases from Jonsbo: the N4, a case designed for NAS. Obviously very compact, this model also offers a special feature: a wooded part on the front panel!
N4: a NAS enclosure with a wooden front panel from Jonsbo!
Jonsbo N4The program includes two variants of this case: one white, the other black. Either way, this model boasts a strip of wood on the front, giving it a classy, sober look.
In terms of dimensions, the case measures 286 (W) x 300 (D) x 228 (H) mm. Weight is of course kept to a minimum, with only 3.75 kg on the scales.
Internally, the special feature of this model is that it offers numerous slots for your storage units. There are two 2.5″ slots, followed by six 3.5″ slots for large hard disks. The point is to build a NAS, but if you can’t fit a big hard disk, what’s the point?
Jonsbo N4
Unfortunately, graphics card compatibility is very limited: four half-height expansion slots. What’s more, length is restricted to just 23 cm.
The same applies to CPU cooling, where you’ll have to make do with a 70 mm-high cooling unit, while the power supply will be in SFX format. As for the board, only ITX and µATX models are accepted.
No price yet.
Jonbso product sheets here and here!
