Jonsbo low profile HP-600 CPU cooler
The Jonsbo brand has come up with a new heatsink for our processors: the HP-600. This is an air-type cooler in top-flow format. Its low-profile design makes it ideal for use in the tightest spaces!
HP-600, a newcomer from Jonsbo!
Jonsbo HP-600With this heatsink, the Shenzhen-based brand offers us a model measuring 120 (W) x 120 (D) x 66 (H) mm. Clearly, it should slip easily into a large number of cases.
What’s more, its 120 mm format allows it to be topped by a slim , 15 mm-thick fan. This fan features an operating speed of between 800 rpm and 1800 rpm. At full speed, the airflow generated is 61.51 CFM, while static pressure rises to 1.71 mmH2O.
Jonsbo HP-600
Finally, the heatsink itself can be mounted on mainstream Intel and AMD platforms. It also features a nickel-plated copper base and six 6 mm copper heat pipes. As for the RAM, it has a 34 mm height clearance.
All that remains is to find out the price, but with Jonsbo, it should be quite affordable. We remember the HX6250, a large single-tower model in 140 mm, sold for around sixty euros!
Click here for the Jonsbo product sheet!
