Intel launches its NUC 13 Pro mini-PCs!
Intel is launching new mini-machines with its NUC 13 Pro, new compact PCs with 13th generation CPUs. Several types of configurations are on the programme, including barebones, ready-to-use configurations and single motherboards.
NUC 13 Pro: a new batch of Intel mini-PCs!
Intel NUC 13 ProIntel is offering mini-PCs equipped with 13th generation processors for businesses and professionals. The latter are also based on the brand’s vPro technology for better security, stability and remote management of the hardware.
However, the particularity of the NUCs is their compactness, for which Intel has opted for a 4×4″ format. Moreover, several formats are offered with ready-to-use machines. Otherwise, the barebone format will allow you to choose the amount of RAM as well as the storage and operating system. Finally, you can buy the barebone motherboard to integrate it into the compatible case of your choice, in addition to choosing the amount of memory and storage capacity.
As far as configuration is concerned, the brand offers Core i7, Core i5 and even Core i3-based configurations. Otherwise, there are two DDR4 SO-DIMM memory slots for 64 GB of RAM at 3200 MT/s. For storage, there are several M.2 slots for PCIe 4.0 x4 SSDs.
Finally, the connectivity gives access to Ethernet in Intel I226 in 2.5 GbE. WiFi 6E is included, as is Bluetooth 5.3. As for the display, there are two HDMIs and two Thunderbolt 4s to manage up to four 4K screens at 60 Hz. And for your peripherals, there are three USB 3.2 and one USB 2.0.
Now, you should know that the announced prices are between 340 and 1080 dollars depending on the configurations and formats.
Here are Intel’s technical data sheets!
