In Win D5: an E-ATX case for reversed-connection motherboards!
A new case from In Win: the D5. In addition to its E-ATX format, this new case features additional openings on the motherboard tray. The aim is to make it compatible with boards with connectors positioned at the rear of the PCB. The famous MSI Project Zero and ASUS BTF!
D5: an In Win case compatible with Project Zero and BTF!
In Win D5In Win’s new case is a fairly basic reference. The front panel is made of mesh, while the side glass is held in place by a quick-release system. Dimensions are classic for a mid-tower case, at 220 (W) x 494 (D) x 473 (H) mm. In terms of weight, it won’t weigh much.
Inside, it is compatible with E-ATX motherboards, but above all, it supports MSI’s Project Zero and ASUS’ BTF motherboards. That’s why there are so many openings on the latter.
For the rest of the components, we have :
  • Graphics card: 365 mm in length
  • CPU fan: 165 mm high
  • Power supply: 180 mm deep
In Win D5As for cooling, this case features a single AN120 fan. Fortunately, if you wish, you can add three 120/140 mm fans at the front and top. As for watercooling, it’s compatible with 360 mm radiators!
All that remains is to talk about the selling price of this model, which currently stands at €129.99 on the In Win online store!
Click here for the In Win product sheet!
