Hyperion GR701 : a big PC case for Asus !
In addition to graphics cards and motherboards, Asus produces some PC cases. The latest innovation of the brand is the Hyperion GR701, an E-ATX model weighing more than 20 kg on the scale. Beware of lumbago!
20.8 kg Hyperion GR701:
Asus ROG Hyperion GR701
In the program, we find a case with a large size with important dimensions. Indeed, they show 268 (W) x 639 (D) x 659 (H) mm and a weight of over 20 kg! On the other hand, these dimensions allow it to accommodate motherboards in E-ATX format.
The same goes for the rest of the components where it will not be limited since 460 mm graphics cards fit without problems. The same goes for the CPU cooling unit with 190 mm of clearance against 240 mm for the power supply.
Finally, it stands out on the watercooling side with a 420 mm radiator support on the front and on the top. On the side of the motherboard, we can install a 360 mm model in the greatest of calm.
Of course, the airflow can be substantial with seven fan slots in 140 mm. In 120 mm, the number goes even further: up to ten fans! All that’s left is to keep your fingers crossed that the airflow at the front is not too obstructed, but it doesn’t look like it.
However, this model seems to have a number of welcome features. The hinged glass panels or the integrated graphics card holder come to mind. Finally, there are two upper handles (supporting up to 80 kg!) that meet at the front to form an X and come down at the bottom to form the feet. Moreover, this element gives it a slight aspect of Cooler Master Cosmo.
