Huntsman Mini Analog: the Razer keyboard with analog switches!
Razer announces a new keyboard with the Huntsman Mini Analog. The 60% keyboard from Razer is equipped with optical and analog switches. In the lot, we will be able to manage the height of the point of accentuation and even parameterize actions according to the level of pressure of the key.
Huntsman Mini Analog: a keyboard with analog switches!
Razer Huntsman Mini AnalogWith this model, Razer continues to offer us an ultra compact keyboard, in the 60% format as a reminder. In addition, this model has new switches, optical and analog models. This means that the keyboard “knows” at what height (between 1.5 mm and 3.6 mm) you press your keys. This allows you to dose your acceleration on a car game for example. Unlike basic switches, there is no “on-off” effect, you can go more gradually.
For the rest, the Razer keyboard has an aluminum construction with PBT keys. Of course, we also find a polling rate at 1000 Hz, the N-Key Rollover or the anti-ghosting integral. The internal memory is also present with the possibility of saving up to 5 different profiles. Before going to the price, you should know that there is a detachable USB type C cable for more mobility.
As far as price is concerned, you will have to count on about $150, which is about twenty dollars more than the basic version.
Here is Razer’s datasheet!
