HF120 White: Enermax fans sold in packs of 3!
Small tour at Enermax which announces a new reference of fans. On the program, the brand offers us its HF120 White mills. White fans, with RGB and sold in packs of three.
HF120 White: three white, RGB fans at an affordable price!
Enermax HF120 White
With this new reference, the brand offers fans in 120 x 25 mm of white color. This model does not leave any room for black, except for the small Enermax sticker on the central hub.
Physically speaking, we find something familiar to Enermax with “double convex” blades. In fact, there are nine of them. On the frame, we will not miss the silentblocks present at the four corners and on both sides.
Normally, these fans should not be too noisy in use. This seems to be confirmed by their speed range: from 500 RPM to 1600 RPM. At full speed, the airflow generated will be 72.1 CFM and the static pressure will reach 1.98 mm H2O.
Of course, we will find a light via twelve LED aRGB positioned on the central hub. Their control will be done either via the motherboard or via the “Control Box”, the classic three-button remote control.
For the price, do not panic, these mills are far from being expensive. Indeed, the brand announces them at 44.90 € the pack of three!
Here is the technical sheet of Enermax!
