H5 Flow: NZXT’s Starfield case!
NZXT brings us its new H5 Flow Starfield Edition. A new limited series featuring a particular theme, in this case, Bethesda’s latest game.
H5 Flow Starfield: a case with Bethesda sauce!
For as long as NZXT has been offering limited edition cases, you’ve heard the song. So, the brand takes a well-known model: the H5, and applies a specific paint job based on the theme of a game, anime, film, etc. Here, the brand takes Starfield and gives its case a futuristic look with a white color. Here, the paintjob reproduces bolts and other spaceship panels.
Otherwise, the game’s logo is featured on the right-hand panel, while inside, we find a rainbow stripe on the case’s cable cover.
Apart from this specific color, the case’s features remain unchanged. We’re still dealing with a mid-tower case measuring 227 (W) x 446 (D) x 464 (H) mm. It is still compatible with 365 mm ATX motherboards and graphics cards. The CPU cooler is 165 mm high.
The ventilation can accommodate up to six 120 mm fans. For watercooling, a 280 mm radiator support is available, while up to two storage units can be fitted.
Availability of the case is set for early 2024. However, we don’t yet know how many units will be available. Finally, it’s already available in a pre-assembled configuration based on Ryzen 7 5800X, RTX 4070 Ti, 32 GB RAM and 1 TB SSD, all for $2,000.
Click here for the NZXT product sheet!
