GSKill Announces 32GB DDR5 Kit at 6600MHz in CL34
After the DDR5 6400 C32 kit, GSKill announces the arrival of a new kit clocked at 6600 MHz CL34 composed of two 16 GB bars for a total of 32 GB. We are therefore on a kit that benefits from very low latency while combining a high frequency. This new kit is part of the Trident Z5 RGB series. It is compatible with the latest 12th generation Intel Core desktop processors and motherboards equipped with the Intel Z690 chipset. The screenshot below shows this 6600 MHz GSKill memory kit validated with Intel Core i7-12700K processor and ASUS ROG Maximus Z690 Hero motherboard.
Le kit GSKill 6600 CL34 As a reminder, the last GSKill kit we had the chance to review was the Trident Z5 DDR5 clocked at 5600 MHz CL36. You can find its test here as well as the overclocking of the latter. You can also find our other tests about DDR5 kits by following this link. The DDR5 6600 CL34 32GB (2 x 16GB) Trident Z5 RGB series memory kits are expected to be available in May 2022 through GSKILL’s worldwide distribution partners.
