Looking to build a new machine, but don’t know which CPU to turn to? It’s a good thing because the Ryzen 5 5600X is currently on special offer in an Italian store. You will be able to order the CPU for less than 200 €, 187.04 € to be precise. You should know that this model is currently available for 205 € on Amazon in particular!
Ryzen 5 5600X : a best seller at less than 200 € !
With this processor, we find a model from the latest generation from AMD. This model has a total of 6 Zen3 cores clocked at 3.7 GHz with a turbo up to 4.6 GHz. On the cooling side, no need to opt for a huge trick because of its TDP of only 65W.
On the motherboard side, you will have to turn to an AM4 model. However, via a bios update, even the first generations are compatible, this is what AMD announced here. But you have to make sure that your motherboard supports this CPU. To do this, don’t hesitate to visit your motherboard manufacturer’s website and check the CPU compatibility!
Ideal to update an old configuration. In any case, to get this model, you should not hesitate to create an account on the Italian store. On the other hand, the order being made in Europe, there will be no customs fees to pay … Just a little higher shipping costs.
Anyway, we thank Matusalem from our Discord server for having spotted the good plan.
Enjoy the Ryzen 5 5600X at 187,04 € !
